Is it possible to create multiple logins for one dashboard?
create multiple logins for one dashboard in Hexnode MDMSolved
Replies (11)
Hope your requirement is to create multiple technicians for a portal. Hexnode lets you create multiple technicians who can log into the portal and access its features.
Please navigate to Admin-> Technicians and Roles and click on Add Technician button to configure a new technician. Each new technician can be assigned any of these roles: Admin, Reports Manager or Apps and Reports Manager. The number of technicians that you can create will depend on the plan that you have subscribed to:
Express: Only Super Admin
Pro: Two Active technicians
Enterprise: Three Active technicians
Ultimate: Four Active technicians
Ultra: Five Active technicians
You can also purchase additional technician license from the Hexnode portal. Please navigate to Admin-> License and click on Upgrade/Renew to find the option for the same.
Check out our help doc on Configuring Custom Technician Roles for more info.
Hi,
My current plan is Ultimate. So I can have a total of 4 technicians. What is the cost, if I need more technician than this?
May I know the plan you have subscribed for? Is that annual / monthly plan?
Annual plan.
Thanks for the reply
Since you have subscribed for the annual plan, for each additional technician, you will be charged $300/year.
Really bothered about the security nowadays. Can two-step verification be enabled for technicians’ accounts? Not really able to trust just on the password login.
Yes, two-step verification can be enabled for technician login.:
- Please navigate to Admin-> Technicians and Roles.
- Click on Add Technician and the option to configure a new technician will appear.
- Check the option ‘Enable two-step verification’.
- Configure other options and click Save.
A new technician is now created and he will be able to log in only via a two-step verification process. You can also edit an existing technician’s details and enable the two-step verification.
Please check out our help doc on configuring technicians for more info.
on reaching the limit, will it be possible to deactivate a technician for a time period and add another technicians for just that period?
Yes, you can deactivate any of the active technicians and create a new technician. To disable a technician, please navigate to Admin-> Technicians and Roles. The list of active technicians will be displayed. To deactivate a technician, turn off the toggle button at the end of the row along which the details of the technicians are listed.
Now, you will be able to create a new technician by clicking on Add technician.
Yes, two-step verification can be enabled for a technician.
- Please navigate to Admin -> Technicians and Roles.
A new technician has now been created. When this technician tries to log in, he will have to enter the username and password at first. The second step is to enter a verification code sent to the email address/mobile number provided by the technician.
