Convert macOS DMG files to PKG filesSolved
2 years ago
I try to convert a .dmg file into a .pkg file as it explain on your website. Unfortunately Terminal on my iMac Ventura 13.5.1 says: error: directory “path_to_savedpackage” does not exist for writing “packagename.pkg”
I search on Google but not found any link for this missing.
Any help ?
2 years ago
Hey @cldjr , thank you for reaching out to us.
You need to provide the actual path to the downloaded .app file and the name with the extension in place of path_to_installedapp/macapp.app. Similarly, you need to provide the path where you want to save the PKG file on the device with a preferred name with .pkg as extension for the file in place of path_to_savedpackage/packagename.pkg.
For example,
Hope this helps!
Regards
Eren Schwarz
2 years ago
Thank you. I’ll try againfollowing your advice.
