Contact sync and Calendar sync for outlookSolved
10 months ago
Hey there,
I am managing a sizable number of Android devices and wondering how I can enable Contact sync and Calendar sync for Microsoft Outlook via Hexnode.
10 months ago
Hi @abbi,
Thank you for reaching out! I’d be happy to help.
You can enable Contact sync and Calendar sync for Microsoft Outlook using the App Configurations feature in Hexnode. Here’s how:
    1. Add the Microsoft Outlook app to the Hexnode app inventory.
    2. Install Microsoft Outlook on your devices using the ‘Install Application‘ remote action or the ‘Required Apps‘ policy.
    3. Go to Policies > Android > App Configurations and click on Add new configuration.
    4. Find Microsoft Outlook from the list of approved apps and click Select.
    5. Enable the ‘Contact sync enabled‘ and ‘Calendar sync enabled‘ options, then configure any other required options or fields before tapping Done.
    6. Click on Add and associate the policy with the required device(s).
Please note that the devices must be enrolled in the Android Enterprise program as either Device Owner or Profile Owner to deploy app configurations.
I hope this helps! If you have any further queries or need assistance, feel free to reach out.
Cheers,
Eden Pierce
