Cisco duo 2fa authenticationSolved
Ideation
It would be great if you could integrate duo 2fa/mfa or at least google authenticator type 30 second rolling codes. Vs text or email…
Hello Raymond
Thank you for your insight. We currently use an MFA (Multi Factor Authentication) for logging onto our portal, via SMS/email. The Google Authenticator type verification is currently a work in progress which we expect to roll out soon enough. As far as the devices’ individual authentication is concerned, it entirely device specific.
In all our supported platforms, we currently have a system where an unauthorized user would not be able to enroll into your portal, called enforced authentication. Our current “Enforced Authentication” (EA) works smoothly across different areas like Azure AD by Microsoft, Google’s G-Suite and, also supports your Active Directory on your local Microsoft Server.
We grow ourselves greatly by listening to what our customers say. It would be of great help for us if you could spend a couple of minutes, help us understand what can be done to better ourselves, hence help us serve you better. Could you please help us understand if you are referring to the portal’s or the device’s authentication?
Thomas Specter
Good to hear this is coming soon. I only ask what that rough timeline is. Q3 2020, Q4 2020?
Hey there,
I have checked with my team and it seems that MFA using Google Authenticator would be released in Q3 2020. Will keep you posted once the feature is released.
