Hey @verbnigge,
Currently, for Windows devices that support multiple screens, there is no option on the portal to remotely choose which screen to cast while using the Remote View feature. Instead, Hexnode UEM lets end-users choose the screen to cast during a remote view session.
To launch Remote View, navigate to Manage > Devices > select the target device > Device Summary > click on the Start Session button under the Remote View window.
This starts a casting session of the device screen on the portal. Now, the user is prompted with a notification asking permission to start the remote view session. After accepting the prompt, the user can then choose which screen to cast if there are multiple screens. The user has the option to switch screens in between a session using the Remote Assist app, but it would only take effect in the next session.
Note that the latest versions of the Remote Assist app and the Hexnode Agent app should be installed on the target device to avail this feature.
Hope that clears your query.
Johan Blake
