Changing the assigned user of a device enrolled in HexnodeSolved
Hi, can I change the user of the device to another one?
Hello Ruben,
Yes, it is possible to change the existing user of a device to a new one. On the remote actions area of any device, upon clicking “Change Owner”, a popup will open assisting you in the process.
Here you can change the user after three steps.
You will have to choose which domain you want to select a user from amongst all your available, configured domains.
Then, you must choose which user you want to assign your device to.
There is an option available to delete the old user’s location history. Checking this option will delete the location history of the device while enrolled with the old user.
CF-2.docx 2019-10-23 22-02-12
You will just have to click “Assign” to enroll the device under your new user.
You can also refer to https://www.hexnode.com/mobile-device-management/help/assign-a-device-to-a-new-user-using-hexnode-mdm/.
Thomas Specter
When the owner of a ios device is changed, will the policies associated with the old owner loose effect on the device?
Yes, on changing the owner of a device, the policies associated with the previous owner will be removed from the device. Also, the policies associated with the new user will take effect on the device.
If mandatory apps have been pushed to the device via policy associated with the previous owner, the apps will be removed if the option ‘Remove apps from the device on policy removal’ under iOS > App Management > Mandatory Apps has been enabled in the policy.
Please check out our help doc on assigning the device to a new user for more info.
