Change Device name for bulk number of devices enrolled in Hexnode using wildcardSolved
How do I change the default device name? After enrolling with Apple DEP, all devices are listed as iPhone. I want to put a wildcard in so it auto updates when we change users.
Hexnode has a feature to assign friendly names.  The following wildcards can be used to set friendly name for the devices: %deviceid%, %mail%, %imei%, %osname%, %serialnumber%, %osversion%, %username%
To set friendly name for large number of devices:
  • Navigate to Manage-> Devices and select the desired devices.
  • Click on the Actions button and choose the option ‘Set Friendly name’.
  • Enter the desired name (can include wildcards). Click Rename.
Need more info? Check out the help doc on setting friendly name using Hexnode MDM.
2 years ago
Is there a way to modify the wildcard: %username% so it remove the SPACE that appears between the first name and the last name?
2 years ago
Hello @dolev-milunsky!
There isn’t a direct way to remove the space from within a wildcard. Although, if you could elaborate on your requirement and the platform of your device, we could try to find a work-around for the same.
