Can’t fetch location in AndroidSolved
I can’t fetch location on my Android device even though I have associated a location tracking policy on the device.
Hi Russel,
Thank you for posting your query!
Kindly ensure the below conditions are met.
  • Make sure “Location Sharing” is enabled on the device and that the device is connected to the Internet.
  • Check the status of the “Scan Device Location” action in the Action History.
  • Please ensure the Hexnode MDM app has permission to access the Location.
  • Please go to Settings > Applications > Hexnode MDM > App Permissions > Location > toggle the button On.
  • Please ensure that your device’s location accuracy is set to High. This helps to pinpoint your location with high accuracy. Please go to Settings > Search for Location > Location Mode > High Accuracy.
    Cheers,
    Nick Parker
  • This reply was modified 5 years, 3 months ago by  nick-parker.
