Can I use personal account for ChromeOS enrollment?Solved
5 months ago
Hi all! We’re exploring options for managing Chrome OS devices in our organization. I understand that a Google account is required for this, but can personal Google accounts be used for device management?
Replies (6)
5 months ago
To manage Chrome OS devices, you will need a Google Admin account provided through Google Workspace (formerly G Suite), as personal Google accounts are not supported for device management purposes. You can check out the official documentation from Google for more information regarding this.
5 months ago
Got it. Are there any costs associated with Google Admin accounts?
5 months ago
Yes, professional Google Admin accounts do come with a cost that depends on the Google Workspace plan you choose. For Chrome OS management, you will need a plan that includes device management features, so I would recommend reviewing the plan details on Google’s pricing page or contacting Google support for clarification on which plan suits your needs.
5 months ago
Many thanks. Does Hexnode support enrollment of ChromeOS devices?
5 months ago
Yes, Hexnode does support the enrollment of Chrome OS devices. This feature has recently been rolled out, so you should check out their enrollment guide for more details.
5 months ago
Hi @margaret and welcome to Hexnode Connect!
Yes, Hexnode supports Chrome OS device management and provides two methods of enrollment:
  1. General enrollment: This method requires manually enrolling your Chromebooks into the Google Admin console and simultaneously into Hexnode UEM.
  2. Bulk enrollment: With Android Zero-Touch enrollment, you can work with a pre-provisioning partner to automatically enroll all your Chrome OS devices into your organization in bulk.
Check out our help documentation on enrolling chromeOS devices for detailed instructions on the same.
