Blocking Microsoft Teams NotificationsSolved
10 months ago Feb 19, 2025
Greetings everyone, I have been working on trying to disable the notifications for Microsoft Teams across macOS devices in my workplace. Users have reported that the frequent pop-ups and alerts cause distractions and disrupt the flow of the work Any guidance would be greatly appreciated!
@Penelope , I believe that using the Deploy Custom Configuration feature you can push a configuration into the macOS devices allowing you to disable the notifications and alerts of apps. I guess, the notifications for Teams could also be restricted in this manner.
@penelope , you can restrict alerts and notifications for Microsoft Teams through Hexnode UEM’s App Notifications feature for macOS. This feature allows you to control the notification settings for specific applications, such as Microsoft Teams, preventing notifications from appearing on your macOS devices. Here’s how you can do this,
  1. Under Policies, go to macOS > App Management > App Notifications and click Configure.
  2. Click on +Add Notification Settings. Then, select the Microsoft Teams app from the list of apps.
  3. Here you can uncheck the option Enable notification to prevent the app’s notifications from being shown in the device.
Configuring notification settings for apps in macOS.
As @skylar-a mentioned, you can also use the Deploy Custom Configuration feature to push a configuration to restrict the notifications and alerts for the app. However, the App Notifications feature is a more straightforward approach for efficient management as compared to custom configurations. For more details on the feature, you can check out our help docs.
Thanks a lot, @kylian_parker .
