Block certain apps from using mobile data, but still runs the app.Solved
HI, does this software allow the administrator to block certain apps from using mobile data while still allowing those apps to run?
Hey, Thanks for posting. Happy to help.
The Mobile Data Management feature in Hexnode lets you set the limit for Mobile Data that can be consumed by an app. This limit can also be set to 0 MB.
Create a new policy or choose to edit an existing one. Navigate to Android–>Mobile Data Management–>App-wise Restrictions. Click on +Add App and choose the desired app. Click Next. You will have the option to Block Mobile Data/All Network Connections and set the limit of Data Usage by the chosen app. Please note to associate targets and save the policy.
Kindly use the help link for a reference on Mobile Data Management.
