can i ask you what is the update period for battery level check on dashboard
Battery level of the device on dashboardSolved
Hey, Thanks for reaching out
- The device details displayed on the portal, such as the battery level gets updated after every scan. The automatic scan happens every 15 minutes.
- Also, you can schedule the device scan by navigating to Admin-> General Settings-> Scheduled Device Scan. The scan can be scheduled on a daily or weekly basis.
- To manually initiate the scan on devices, navigate to the Manage tab, select the desired devices, and choose the ‘Scan Device’ option by clicking on the Actions button.
Kindly use the help link for more info on the same.
Can the admin be alerted when the device battery level falls below a specific level ?
Yes, the admin can be notified when the battery level falls below a specific value:
- Please navigate to Admin-> General Settings-> Battery Level Alert.
- Set the desired battery level.
- Go to Admin-> Notifications-> Notify the administrators on and select Device battery level.
- Click Save.
The admin will be alerted via email when the battery level falls below this value.
Please check out the help doc on General settings for more info.
