Battery level AlertSolved
6 years ago Mar 19, 2021
Is there any way the Admin can receive a notification when the device battery level goes below a certain value? It would be great if I can choose the value from the portal.
Hi Stefan,
Greetings from the Hexnode team!
Yes, it is possible for the Admin and users within the Hexnode portal to receive the email alerts when the battery level within the devices goes beyond a certain value.
You would be able to set this value from the Hexnode portal itself.
Just navigate to Admin > Notification > Select the Checkbox ‘Device Battery level’.
Once this option is enabled, a slider would be displayed which you can adjust in order to set the required battery level. You would be able to set the battery level from Admin > General Settings > Battery Level as well.
Eva Tyler
