Azure AD for DEP enrollment, and more.Solved
Are you looking forward to enrolling your Apple devices to DEP using your Azure AD domain? Hexnode got it covered in our latest release.
With this, you can now enroll Apple devices to DEP using your Azure AD credentials. All you need is to configure Azure AD followed by authenticating the enrollment using Azure AD domain.
Here is how you can do this!
  1. Login to your Hexnode portal.
  2. Configure Azure AD.
  3. To enroll devices using DEP, Navigate to Enroll > All Enrollments > No-Touch > Apple Business/School Manager.
  4. Click on Configure DEP Account.
  5. Follow the steps as per the documentation and under User authentication, choose your Azure AD domain and set a default user.
Launcher customization for Android Kiosk.
In our previous release, we have included an option Customizations under Policies > Kiosk Lockdown > Android Kiosk Lockdown > Launcher. This feature is now enhanced by adding a custom app icon size.
With this, you can now customize the icon size of the app to the required pixels using Hexnode.
  2. Navigate to Policies > Kiosk Lockdown > Android Kiosk Lockdown > Launcher.
  3. Click on Configure.
  4. Under Customizations, choose the Icon size as Custom.
  5. Set app icon size in pixels. The minimum and maximum values are 36 and 150 respectively.
Have a look at Launcher customization to know more on this!
