Hi @Fengge, with Hexnode UEM, you can automatically mandate OS updates for your Mac. Please note that only managed macOS devices enrolled in the Device Enrollment Program (DEP) and running macOS 10.11+ are eligible for OS update management.
With this feature, you may instruct the devices to download or install an update as soon as it is available. You can configure a policy for this from Policies > New Policy > macOS > Security > OS Update. You may select any one of the following options –
Option |
Description |
Notify Only |
Download the software update and notify the user through the App Store. |
Download Only |
Download the software update without installing it. |
Download and Install |
Downloads the updated version and starts installation immediately. Installation begins If the software update has been previously downloaded. |
Install |
Install an already downloaded OS update. |
Install Later |
Download the software update and install it at a later time. |
Learn more about the feature.
Zach Goodman
This reply was modified 3 years, 10 months ago by
Zach.
Zach.
Zach.
Zach.
