We use firefox as our default browser on our android devices and it eats up a lot of our device storage. Can we auto clear the data stored by the browser on the devices by any chance.
Auto clear firefox dataSolved
Hi @pau,
Currently, Hexnode UEM does not offer the feature to automatically clear the app data on Android devices. This is a great feature recommendation, and we will check with our developers to deliver the feature at the earliest.
Instead, there is an option to manually clear the app data on Android devices using Hexnode UEM. To access this feature, head over to Manage > Devices > select the required device > Applications and search for the Firefox application. Click on the settings icon corresponding to the application, which opens a dropdown menu. Now, select the Clear App Data option from the menu. Confirm the action with your login password when prompted.
To clear data of applications for multiple Android devices simultaneously, navigate to Manage > Devices > select the target devices > Actions > Clear App Data. Select the required applications from the list and click Next. Now, enter the number of selected applications and click Clear Data. When prompted for confirmation, enter your login password.
Hope this clears your query.
Johan Blake
Does this apply to all my applications on the device.
Hey @roosevelt,
There are some applications that don’t support the action to clear data.
- Data of system apps and applications with Device Admin privileges cannot be cleared.
- Data of some applications may be stored in external storage or in folders that do not belong to the app. In such cases, the data cannot be cleared.
Note that this feature is supported only on Samsung Knox devices and Android Enterprise devices running on Android 9.0 or above.
Hope that helps you.
Johan Blake
