Audit ReportsSolved
7 years ago
Much like the other reports, your Audit Reports (Reports > Audit Reports) can now be filtered by one or more tags.
Apart from the audit history, what are the other audit reports available?
You can find the report on Action History, that gives the complete list of all actions executed on the enrolled devices. Please navigate to Reports-> Audit Reports-> Action History to find the same. You can filter the list based on the status of actions executed on the device and also on the time the actions were created.
You can export this report as a PDF/CSV file. For this, click on the Export button at the top and select the PDF/CSV option based on your requirements.
Check out our help doc on Audit Reports to know more on the same.
