Assign to groups within DevicesSolved
Ideation
3 months ago
I do a lot of group changes when we upgrade iPads.  Adding to groups, removing from groups, but it isn’t in batches (all these ipads need to be added, though it does happen as well).  What I’m proposing is that when looking at a devices groups, to the left the of the search, if I had the ability to add and remove from a group  right here.  As it is, I open 3 windows (usally one for device, and 2 for the groups they are usually added to or removed from) and switch between the windows.  Even at that, there are lots of keystrokes involved in processing an iPad.
Open device, switch to the groups it belongs to, click the button to add or remove from here.
Just like when you add a device to a group from within groups, it opens a search window of groups and lets me check mark the ones I want to add it to.
Would save a lot of my time.
3 months ago
Hello @livewot
We understand the requirement and the workflow you’re proposing. Currently, Hexnode UEM doesn’t support adding/removing devices from groups directly within the device view, but we’ll share this suggestion with our team for consideration in future updates.
Let us know if you have any further questions!
Eden Pierce
