Apps suddenly crashes in iOS 14.2Solved
Installed the app Insightly in a couple of iphones.When I try to open it, it crashes almost immediately. Here is the weird part: It happens only in iOS 14.2 of iPhone 11
Doesn’t seem like a Hexnode issue.
Hello Fabio,
All the apps developed using Xamarin crashes upon launching in iOS 14.2. Unfortunately, Insightly is one of them. This is an issue that we face due to a bug in iOS 14.2. It has been widely reported in Apple Forums. The problem seems to be resolved in iOS 14.4. So kindly update your devices to iOS 14.4 or above and check if the issue persists.
Installing the app without using Hexnode might also solve this issue, as the problem occurs due to the incompatibility of Xamarin and the UEM.
Cheers!!
Deborah Timothy
