Deployment of app catalogs to devices in Hexnode MDMSolved
I have created app catalogs under the Apps tab. How can I get them to the devices?
Hey, Thanks for posting. Happy to help.
After the App Catalog is created under the Apps tab, navigate to the Policies tab. You can either create a new policy or choose to edit an already existing one. From Android/iOS > App Management, select App Catalog and click on ‘Configure’. Click on ‘+Add Catalog’ and choose the desired catalog. Click Done. Associate targets and save the policy. The catalog will be deployed to the device.
Kindly use the help link for App Catalog for more info.
Kind of new to Hexnode. Just finished configuring VPP. Can I add apps to iphones through this catalog?
Hello Antwon,
The app catalog is a custom app storefront that lists the apps that the end-user can install on their device. Apps in the app catalog do not get installed automatically. VPP apps also can be added to the app catalog. Read our help doc to know more about app catalogs.
If you are looking to deploy apps to the device, refer to our help doc on app installation.
Cheers!!
Deborah Timothy
