App update in kiosk for AndroidSolved
When I update the APK file for an enterprise App, does that automatically update it on all devices or I need to reapply the policies using that App such the Kiosk lockdown?
Hi Matilda,
Thanks for posting.
When you replace the APK file in the Hexnode repository, the policy will get updated automatically. You don’t have to re-apply the policy.
However, the way each device reacts to the update will be different. Certain devices support silent installation without user intervention. However, many devices require you to manually update when a ‘wrench’ symbol appears on the app icon in the kiosk.
Please use the link for further reference.
