App Store missing on iPhoneSolved
3 months ago
Hello everyone! My App Store has vanished from my iPhone, and I’ve tried everything I could think of with no success. What’s strange is that I recently switched to a new iPhone, and the App Store is missing on this device too. Has anyone else dealt with this or knows how to fix it?
3 months ago
Hello! I had a similar issue with an app called Cape, which hides other apps. Disabling its Screen Time Access resolved it for me. Do you have any apps like that installed? If so, try disabling their access, it might help!
3 months ago
@otis, you should check your phone’s restrictions. Sometimes, the App Store can be hidden due to certain settings. Go to the Settings app, then open Screen Time. Look under Content & Privacy Restrictions and ensure that Installing Apps is set to Allow. This might solve the issue. Let me know if it works!
3 months ago
Thank you, everyone! I finally got it sorted out. Here’s what worked for me:
  1. Turn off Content & Privacy Restrictions entirely: Settings > Screen Time > Content & Privacy Restrictions > Toggle it off.
  2. Disable Share Across Devices: Settings > Screen Time > Share Across Devices > Toggle it off.
  3. Restart your phone and search for “App Store” in the App Library.
If anyone else is facing the same issue, give these steps a try! 😊
