App Installation on Apple devicesSolved
Hi when I start Install application action and see success in the action history. Does it mean application installed to the device? Or it means action initiated successfully and the rest is depends on Apple?
Hey, Thanks for posting the question.
When the Action history status for App installation is shown as ‘Success’ it means that the app is successfully installed on the device. If the device is in Kiosk mode, an icon will show the app being installed on the device and once the installation is complete you cannot find the app on the kiosk screen. But once you exit the kiosk mode, you can find that app on the home screen.
Click here to know about iOS app installation using Hexnode MDM
