App icon size in kioskSolved
Hey
Can we increase or decrease the app icon size in kiosk mode, so that a great visual satisfaction can be provided because the screen size may vary in size.
Hai,
Thanks for posting the query!
Yes, you can customize the app icon size in kiosk mode. While setting up a single or multi-app kiosk policy, choose ‘Launcher’ under ‘Android Kiosk Mode’. Under Customizations, kindly enable ‘customize kiosk launcher’, and choose the ‘icon size’.
The ‘Icon size’ will have four options to choose from. If the option ‘custom’ is chosen, you can set the size of the icon manually.
Please use the link for reference on the same.
