Android Enterprise account removedSolved
2 years ago
Hi, I’ve been trying to enroll my devices in Android Enterprise as device owner but I’m getting an error saying that Android Enterprise has not been configured for my organization. Does anyone have any idea what might have happened?
2 years ago
That’s probably because your Android Enterprise token has been removed from the google admin console. That’s assuming that your organization was enrolled with the google domain.
2 years ago
Yeah I’d enrolled via Google domain, is it possible to re-enroll?
2 years ago
Yup, you can re-enroll your organization. You just have to login to your google admin console (just to be sure, check whether Android Enterprise has been disabled for your Organizational Unit) If it is disabled, you can re-enroll your organization by generating a new token.
2 years ago
@_patricia_, thank you so much for helping out, I’ll take it from here 🙂
@frida, you can generate a new token as shown below:
Generate token to re-enroll Android Enterprise account
Once the token is generated, paste it in the Hexnode UEM portal. You can enroll your devices in the Android Enterprise program just like you used to.
Do have a look at our help document for a step-by-step guidance on re-enrolling your Android Enterprise account.
Hope this helps with your query.
2 years ago
Appriciated. Hats off to the support team.
