Allow non-admins to disable automatically joining a networkSolved
1 month ago
Hey,
Our organization manages macOS devices, and users often experience their devices automatically connecting to previously saved networks due to auto-join being enabled. However, when they attempt to disable auto-join, it requires admin privileges.
Is there a way to let non-admin users control this setting without IT intervention? Any insights would be appreciated!
Notification for administrator credentials while changing Wi-Fi settings.
Replies (7)
1 month ago
Have you checked Hexnode’s Wi-Fi settings? You can try unchecking the Auto-join option there. Here’s the link: Auto-join.
1 month ago
I think that only applies to new networks deployed via Hexnode, not existing saved networks.
1 month ago
Hey, try running these commands in Terminal, or push them via execute custom script in Hexnode:
1 month ago
Thank you! That worked perfectly.
1 month ago
Anything to prevent my Windows devices from automatically connecting to untrusted open Wi-Fi hotspots?
1 month ago
Hey, we have implemented something similar. These are the restrictions that we disabled:
List of restrictions to be used for Windows.
The first restriction we disabled should cover your needs. I’d also recommend taking a look at the second one – it makes sure users only connect to Wi-Fi networks set up through MDM.
1 month ago
That did the trick, thanks.
