After disenrollment, will the apps deployed via Hexnode be removed?Solved
After I disenroll an android device, will it still be operational? (i.e. can it just run the installed apps without restrictions, after we remove device from Hexnode). we have an app, that is installed using the mandatory apps policy
If you have not enabled the option ‘Remove apps from the device on policy removal’ in the Mandatory app policy, the app will not be removed from the device on disenrollment.
To find if the option is enabled, navigate to Policies tab and click on the Mandatory app policy associated with the device. Go to Android-> App Management-> Mandatory app, you will be able to find the option. If the option is checked, you can uncheck it and save the policy for the app to remain in the device after disenrollment.
