Advanced Scripting for MacSolved
1 year ago
Tired of keeping track of and routinely running scripts on your devices?
We’ve got you covered on that as well. With Hexnode’s advanced scripting feature for macOS, bid farewell to your scripting worries. You can now pre-configure the scripts you need and run them at device logon, logoff, startup, shutdown, or a custom time interval.
To avoid any complications, please make sure to ensure the following before executing the script in bulk:
  • The latest version of the Hexnode UEM app is installed on your target devices
  • All the scripts have been manually validated beforehand.
You can configure advanced scripting for macOS from Policies > macOS > Configurations > Scripts.
macOS login logoff script
It might take a while before the feature reaches you. In the meantime, you can have a look at our detailed documentation for more insights on how the feature works. And as always, if you have any other or feedback for us, you can always reach out to us at support@hexnode.com or ping us here at Hexnode Connect.
