Adding apps to Android KioskSolved
hey everyone! We’ve pushed our work app in an android kiosk and it seems as though they’re unable to add any files from the file manager. They need to do so to send different images etc to our clients. Any solution?
Replies (8)
i just pushed a kiosk policy with gmail. Checked and facing the same problem… thanks for notifying this issue. Hope someone can help
y’all can just add the file manager app to kiosk!!
tried, not working 🙁
Not sure if I proceeded the right way though
Hi everyone, thanks for posting on our forum!
You can add the file manager app on your device to the multi-app kiosk, @Grayson. This can be done by navigating to Policies > Kiosk Lockdown > Android Kiosk Lockdown > Multi App Kiosk. Then add the required app by clicking on the ‘+’ button in the basic view, or drag and drop the required apps in advanced view. Associate the policy with the device once you are done with the configuration.
Feline Jones, could you please tell us the devices that you are handling? The issue could be occurring because of a wrong app being added.
Gabriel Galbraith
Hexnode UEM
  • This reply was modified 3 years, 10 months ago by  Gabriel.
yeah, we use OnePlus phones.
Thanks for your response, Feline Jones!
You can add the required app to a multi-app kiosk after checking its corresponding bundle ID from the Applications subtab in the Manage tab. In your case, if you are using the default file manager app, please add the File Manager app with the identifier com.oneplus.filemanager in the kiosk policy. Please check and update if this works for you. You can find the detailed steps in this troubleshooting documentation.
This will let the users access the app in the kiosk. Please refer to the documentation on multi-app kiosk for detailed steps.
Adding an app to Multi-App kiosk
Hope that helps.
Gabriel Galbraith
Hexnode UEM
We have added 3 apps that we need in multi app kiosk. Company policy is to not give our employees unrestricted access to apps like file manager/my files, gallery etc.
Hey there, @Grayson! Thanks for reaching out to us.
We understand the need for your company policy. It is precisely to help you in this sort of dilemma that we have the Background Apps feature. With this, you can add the required app under Policies > Kiosk Lockdown > Android Kiosk Lockdown. You can add the File Manager app corresponding to your device here. The apps that you add here will not be directly accessible in the kiosk, but any particular app that is directly used by the employees can invoke this app.
Feel free to ask if you’ve any more doubts, or you can refer to the documentation on
background apps for more info.
Hope that helps.
Gabriel Galbraith
