Add directories to content area, and allow for file renaming during transferSolved
Ideation
I have a request to add the ability to create folders within the content area.  This would allow for better management when the list of files available to profiles gets longer.
Also, I would like to recommend adding the ability to alter the file name during transfer (default: same file name).  This would also mean allowing multiple transfers of the same file as long as the destination file were different.
See example mock attached:
sample
Hi Tylor,
Hope you are doing well,
We understand that this option would be quite helpful as you look to create folders and populate them with the required files from the contents tab of your Hexnode portal. This shall help simplify the file management and ease the deployment of the folders to the devices as well.
We appreciate you bringing this to our attention and we shall raise a feature request on your behalf and keep you in the loop with the updates. We shall also look into the option of having the filename edited from the policy as well.
Stay safe and have a great day!
Cheers,
Jeff Black
