Hello @zariah. Good question you have there! It’s easy to mix up the statuses, so here’s a quick breakdown:
- Cancelled: This status can appear in two instances:
- Action manually cancelled: Appears when the action is manually cancelled by the user from the Action History.
- Action reinitiated: If the same action is initiated again before the previous attempt is completed, the earlier attempt will be marked as Cancelled with an information icon alongside it, indicating that the action was reinitiated.
- Failed: This status means the action couldn’t be completed due to an error or issue during execution.
Hope that clears things up!
