Ability to Edit the Desktop Apps Added in Windows Kiosk Lockdown SettingsSolved
Ideation
2 years ago
Please make it so that you can edit each added application in the Kiosk Lockdown Section. It is very difficult to check for errors, all you can do is delete and add back, also hard to tell whats what, and what you have and dont have. All you can do is Add and Delete, this really really needs an edit option as well.
Hexnode Kiosk Lockdown Screen
2 years ago
Hello @CareArc, welcome to Hexnode Community!
I’ll definitely take this up with the team and see what can be done. I’ll get back to you once we’ve determined the scope of the feature and how soon it can be implemented.
In the meantime, would you mind elaborating on the errors that you mentioned? It could help us guide you more effectively.
